KNs Street Metal Series HighFlow Air Intake Systems provide a good looking appearance,offer increased airflow and deliver more horsepower,torque to your HarleyDavidson motorcycle. These intake systems increase power by eliminating the stock OE air cleaner and replacing it with a complete HighFlow Air Intake System. The sturdy,custom aluminum backing plate mounts directly to the throttle body via an aluminum integrated,internalrun breather system. The intake system comes with a KN Air Filter for high air flow and long service intervals. A durable mounting gasket is also included to help absorb vibration. The KN HighFlow Air Filter is washable,reusable,preoiled and ready for installation. Simple designed custom covers give this air intake good looks while powering down the highway or at your local show.RK Series Street Metal High Flow Air Intakes for HarleyDavidson MotorcyclesDesigned for HarleyDavidson motorcyclesIncrease horsepower and torqueEasy to installMade in USABacked by KN warrantyPart RK3934 Product SpecificationsProduct Style: Motorcycle Intake SystemEstimated Horsepower Gain: 10.23 HP,5155 RPMStreet Legal In All US States: NoAir Filter Color: RedTUV Approved Europe: NoAir Filter Height: 2.25 in 57 mmAir Filter Inside Diameter: 6.125 in 156 mmAir Filter Material: Cotton GauzeAir Filter Outlet Shape: Not FlangedAir Filter Shape: RoundClamp Material: No Clamps RequiredClamp Style: No Clamps RequiredColor: RedFilter Material: Cotton GauzeInlet Diameter: 2.4 in 61 mmIntake Pipe Ports: All intake tube ports needed for the specified applications are includedMass Air Flow Sensor Adapter Included: Mass Air Flow Sensor Adapter Included When RequiredMounting Hardware Included: YesNeck Flange: 2.4 in 61 mmOverall Height: 2.5 in 64 mmReplacement Filter: E3336Size: 68Style: RoundTop MaterialFinish: ChromeTop Style: ChromeVacuum Tubing Included: NoCalifornia Restricted: Not legal for sale or use in CaliforniaWeight: 4.8 lb 2.2 kgProduct Box Length: 11.75 in 298 mmProduct Box Width: 9.5 in 241 mmProduct Box Height: 4.88 in 124 mm
Store | Price |
Cruiser Customizing | [show price] |
This K&N Products RK Series Street Metal High Flow Air Cleaner Kit Weld Style Chrome- Harley Davidson Dyna Softail FL Models 99- Up - RK-3934 is nice to use. I recommend buying this product from this Cruiser Customizing , because here it has good, reasonable 418.16
