This customized Smart Kit combines top knotch products from two of the industry's leading manufacturers; brining superior quality and style to any kitchen Smart Kit Includes: Blanco double-bowl SILGRANITE II kitchen sink with 60/40 split (440179) Moen Pull-out spray kitchen faucet from the Brantford Collection (7185) Sink Features: Sink is constructed of Blanco's patented SILGRANIT II - high grade granite composite Fully covered under Blanco's limited lifetime warranty Double basin design - features a 60/40 split Installs in an undermount configuration Durable finishes - resists staining, chipping and scratching Included Free - 2 fitted basket strainers Drain located in rear of basins All hardware required for mounting is included Faucet Features: Faucet body and handles feature solid-metal construction Fully covered under Moen's limited lifetime warranty Moen's faucet finishes are designed to resist corrosion and tarnishing Smooth single handle operation (handle included) Features a swivel spout design A pullout spray head enhances functionality and water control Optional-use cover plate (escutcheon) included - for sinks with 3 faucet holes (8" centers) ADA compliant; low lead compliant Sink Specifications: Height: 9-1/2" (measured from the bottom of sink to the top of the rim) Overall Width: 19" (measured from the back outer rim to the front outer rim) Overall Length: 32" (measured from the left outer rim to the right outer rim) Basin Width (Left) : 18-5/8" (measured from the back inner rim to the front inner rim) Basin Length (Left) : 16-1/2" (measured from the left inner rim to the right inner rim) Basin Depth (Left) : 9-1/2" (measured from the center of basin to the rim) Basin Width (Right) : 16-13/16" (measured from the back inner rim to the front inner rim) Basin Length (Right) : 12-1/2" (measured from the left inner rim to the right inner rim) Basin Depth (Right) : 8" (measured from the center of basin to the rim) Faucet Holes: 0 (number of pre-drilled faucet holes on sink) Drain Outlet Connection: 3-1/2" (compatible with almost all garbage disposals) Minimum Cabinet Base: 36" (space recommended to install sink) Faucet Specifications: Overall Height: 15-1/2" (measured from mounting surface to highest part of faucet) Spout Height: 8-1/4" (measured from mounting surface to spout outlet) Spout Reach: 7-7/8" (measured from center of faucet base to cneter of spout outlet) Faucet Holes: 1 (number of holes required for faucet installation) Flow Rate: 1.5 gallons-per-minute Installs onto decks up to 2-1/2" thick Designed to easily connect to standard U.S. plumbing supply bibs
Store | Price |
Build.com | [show price] |
I right bought this exclusive Build Smart Kits B440179/M7185 Oil Rubbed Bronze Faucet Build Smart and im bright with my acquire.
